Brookhouser Engines
German D-179 pistons with only 3 ring grooves not 4
rebuilding a D-179 forktruck engine. IH dealer says they were only built with 4 ring groove pistons. This one only has 3. All dimensions are as printed in repair manuals and all crankshaft specs are consistent with manuals. Looking for std replacement rings. Any thoughts ?
try hasting rings,if the old man is alive they will make them
illst 144 may also be helpful....jimb2
On 3/23/2020 at 4:09 PM, Brookhouser Engines said:
rebuilding a D-179 forktruck engine. .........
A ring job isn't a rebuild.  Put new pistons and liners in, that's a rebuild.
As far as "standard" rings go, they come with new pistons.
Is this the illst 144 that you want?
yes it shows the current torque + type of bolts,(single use)?
but today we need to know (as many fail)if to also replace factory  bolts/studs and where to get them $ not $$$$
we dont know how far OP is into it....
I would add per above if sleeves /piston  check out and rings are bad,would seriously consider NEW hasting rings ONLY over a reliance kit........but would inspect those sleeves for cavitation and clean change the orings regardless
I agree.  But if you are going that far, not many more $$ to just replace them.  Labor is the same.  Easier to warranty new parts than just labor.  Hard to give a long guarantee on old parts.
Lots of d-179s built with three ring pistons you have to determine if the top ring is rectangular or keystone and then order the appropriate ring set  not a big deal
