Bitty Built MFG
bitty
8 minutes ago, searcyfarms said:
looking good............we had a yerf dog some years ago for the kids, it had a 6.5 hp on it and some kind of dual speed belt clutch on it, boy it worked slick, plenty low end and then some zip when you got going down the road - really was a good lil cart with roll cage etc.....not built as solid as yours to say the least but never gave us any troubles -
We bid on a yerf dog but it went more than I believe it was worth. We will spend a little more than the used cart at the auction that needed some parts and tinkering also
maybe u can find out the clutch/belt setup on that yerf and put one on yours, it really worked slick, but you had to keep it clean or it would stick in low and never go over to the high side.
i gave 600 for ours it was a 2 seater and in like new condition. A guy bought it for his grand kids to ride when they came to visit and they moved out of state so it was hardly used.
We had it about 5 yrs and sold it for 750 - it rode well with the flex rear suspension on it too. - it was a 2 seater. - ours was like this one
https://photos.offerup.com/otyvMRFhrJzKL7sn8oGAQg3EIY0=/600x450/bf2a/bf2a9fd08f4647599d1232b016c2273f.jpg
https://photos.offerup.com/6IkI6l0MZVx21ymu7lQomCC4Wkg=/600x450/5ac9/5ac966dd1bfd43d2a5cee7bea394cf44.jpg
Yes we have a torque converter ordered. Basically a snowmobile transmission LOL
Parts came today at lunchtime. We assembled the torque converter and tires are on the rims tonight. IMG_20200508_185658587.thumb.jpg.9ed5da10b01c926ac0193bfb3b2bd7a5.jpg
Have to get two sprockets and a jack shaft with bearings yet to reduce the speed because of the rear tire height
  • Like 7
Missed a few pictures
  • Like 5
2 hours ago, Rawleigh99 said:
I bet your son is anxious now!  So close he can probably taste it!  He will remember this for the rest of his life!
He is extremely anxious but unfortunately I am really busy with spring work
great job there fellas, getting closer to the real deal, dont forget to make a trailer so he can haul out  water kegs and lunch to you in the field or maybe u can make a box behind the seat for that !!!!
47 minutes ago, nomorejohndeere said:
Ad says he used it around the house but has no use
Lincoln Weldonpower 130
Looks neat
  • 1 month later...
Slow going, haven't touched it in a while until today. Hopefully it will get done soon if I can stick to a few hours every few nights. Decided to add a rear swing arm suspended engine frame
i been wondering where that project was at, gosh its a busy time of year now for so many of us - hard to stay on top of the projects, that rear swingarm  suspension will help the ride a lot - keep pluggin away i feel like im eating an elephant around here sound like many of us are!!!
We finished second cutting over a week ago, manure is spread to grow third if it rains any. I am mostly caught up with respraying corn. Biggest thing I need is to get ready to put a small shed up at home. I have to haul 15 more loads of shale to get the pad leveled up.
im heading up to mom/dads tomorrow to take the 2355 off the 5088 - dad said the air is not cold - called teh guy that fixed it and he said the condensor is probably dirty and he cant check/clean it w/out the loader off - hmmmmm - i have taken that side cover off before with the loader on and hosed things off and its only been 15 hours since the entire system was updated outside of teh condensor - so I will be calling him out to see if 15 hours could have clogged it up already - i dont think so but will find out - pressures are running high on it he said when he checked it this week so he said its got to be clogged up in there.
I am working on getting AC on my 706 - will divulge that when i see if it actually works, im fabricating and learning as I go and i dont want you guys to talk me out of what i am doing LOL
I know some will call me an idiot but hey...........im trying to save a buck here
I joked with George that I was going to put a tub of water on the roof so it would slop on him as he goes over bumpy ground. This coupled with wind in his face would cool him off .
  • Haha 3
What cab do you have on your 706?  I have a Year A Round.  I will be interested in your progress!
mines a diamond shaped hinson - i test fit a condensor in front of the radiator last night, too tight GRRRR it woudl fight but NO ROOM anywhere around it also not quite deep enough in front of radiator - back to drawing board...........on plan E at this point - trying to keep it under 500bucks its going to be a challenge but i shall succeed - no more 10 foot doors for teh 706 going to have to go to 12
found a sanden with dual stack pulley - might get that to use and stack the alternator but still pondering..........
Some more progress. I should have gotten 4 weld on bearing mounts. Might have to make the second pair for the jack shaft
lookin good, i remember oh so well the days of shorts n my rubber chore boots, sores on my calves from them rubbing and chaffing in the hot summer weather - bring on the gold bond!!!
made it up/back to work on the 5088, clean out radiator/condensor - replaced the foam with a couple pieces of old carpet and wedged them in the hole in the bottom to block airflow from underneath instead of down through the top like its supposed to go. Have to get some rubber foam to go in there wont keep the carpet in it. Found the alternator is bad AGAIN, just had it rebuilt but our wiper motor shorted internally and we are thinking that might have made it fail prematurely. I also went thru the condenser with a popsickle stick and opened up all the bent fins and hoping that will fix things, if not potentially thinking of adding a couple small 12volt electric fans to move more air through it. Guy that worked on it last summer and put all the new stuff on is coming by this week to test pressures again after cleaning.
1099271651_5088-2.thumb.jpg.4c545e2b9547c577e26c6f30861fae28.jpg1463599892_5088-3.thumb.jpg.febbb33428faf4668f16b93ed6d12bf8.jpg1234080132_5044-4.thumb.jpg.c46dcbd821fdc55cd5447f98cf6c5f43.jpg1973571360_5088-5.thumb.jpg.fd7e4a2847066ee8b28f8308e7c7ada1.jpg
Hey George, that seat is looking too dusty. get in there and shine it up!?
  • 3 months later...
A 42' pump we bought new was getting thin and then we flipped it and ruined it trying to set it up again. We decided to reuse the driveline, pump and a few other things to remanufacture it.  I am running an 8" schedule 40 steel pipe parallel to the driveline tube for additional weight for stability and rigidity. I will try to add pictures as I work on it
