1952 Allis Chalmers WD
Well she’s done ( not completely). I can’t decide if I want to just clean overspray off the rear rims or paint them.
  • 1 month later...
Wow I was reading through my post and relized I haven’t gave y’all a update in awhile. Not a lot has happened to the wd other than painting the rear rims. Here’s just some pics of stuff I’ve done with it around the house.
Now that the tractor is done it was time to start on the plow to show with the tractor. Since everything slowed down I went ahead and repainted the plow to match. Hopefully soon I will be able to test it out
TN Hillbilly
Yes. I don’t know what happen I got it that way. Would like to find the old farmer who had the tractor before I got it to ask him what he did
I've seen a few of those moldboards broken like that, always makes me scratch my head. Wear parts for Allis plows are a little hard to find. Not impossible, but not easy. I have a model 52 and a 53 simply because they have great shares and such on them, and the price wasn't too high.
18 hours ago, Tj01 said:
TN Hillbilly
Backed up with plows down, or was stuck and pull it out backward I’d my guess
I was thinking that he backed into something. You may be right though
Check out witmers ?  ac in west Salem, Ohio I bet he has the mold boards if you want to get replacement , but it if you going run it hard use what you got they work right ?
or plowox
ain’t the first time a welded moldboard lasted a lifetime
or plowox
It’s Wellert’s AC Parts in West Salem. Phone number should be found easily with Google. If you have trouble locating it,  I can get it for you.
Thank you very much for correction wellerts
witmers is Agco in columbiana,Ohio my stake
Dt Fan
Thats a nice WD45. Wouldn’t mind to gets some weights like that for the front of mine but haven’t found around here. That’s a good looking 45. Looks great
Run it , , Take  some photos for us, AC designed plows are as good as they come ,we have a set of trailer 12 s behind the Farmall C and the C likes them ,I feel it will make me a also ran in the plowing competitions , I’vee honestly had an old farmer son tell me that’s a hot set up . Make a feel good .
  • 3 months later...
So after I got most of my projects done I bought this Oliver plow master 100 trip plow to pull behind my 1942 John Deere B. (I know the words John Deere are not suppose to be in here). I got the plow a moving yesterday and hooked it up behind the wd due to I’ve got the Deere tore down completely so I can replace leaky axle seals. Hopefully I can get a local company to sandblast it for not too much so I ain’t got to grind it. If y’all would like to see some pics of the Deere tore down just let me know
TJ, it would be interesting to see how that plow worked behiind the WD. The traction-booster works so good on my 45 that going to a pull plow might seem like going backwards. I have Dad's model 70, (I think) IH 4-14 with rear bottom removed that I could try sometime. Need to get it out and re-coat the bottoms before they rust.
I get all kinds of silly plowing ideas bouncing around in my head! Have a snap-coupler to three point adapter that would mount my 4-14 Oliver on the 45. In good conditions she would pull it fine, just not sure where the good conditions are. Everywhere I plow the dirt seems like concrete!
Dt Fan
I know what you mean. All we got around here is red dirt and it's hard to plough. Idk how the pull type plow will work I will just have to try it out one day. The main reason I got it was it was cheap and would give something to show with my John Deere.
  • 4 months later...
When I got my WD the headlight on the left side didn’t match the one on the right. So finally after almost a year I got a matching headlight. Went ahead and switched the bulbs to LED’s so I could see better.
Nice tractor. Would love to have a WD45 Diesel
