TD9B torque converter trouble
TickyB
10 hours ago, TickyB said:
do you have a part number for the lower air filter? the number on mine is not legible.
Lower Air Filter? I am unsure of which filter you are asking about, I am unaware of a lower air filter, are you wanting transmission filters? There is a transmission pressure filter and a transmission suction filter. If you are wanting air filter elements there is the std. air filter or there was a heavy duty attachment air filter. I need more info and the serial number of your tractor.
The left one in the pic below is the upper, the other is the lower which I don’t have a number for.
There is a later version (serial numbers 15967 to 15993 and 16218 up used an inner and outer filter. This is the air filter on a TD9B Ag tractor, they all looked like this with the exception of the Heavy Duty air filter. Do you know the serial number of your tractor or post more pictures, I can then get you either the IH part number or convert it to a WIX part number.
