1965Dennis
656/706 D282 Oil Filter
I have a 656 diesel that is leaking bad around the bolt that holds the oil filter canister on. My parts book does not show it so I went to the trusty dealer and they have no idea what part number or sizes to look for. Said if I bring in the old one, they might be able to match it up with something. Does anyone have the part number or a replacement o'ring size I need?
I think the washer is part of the oil filter bolt assembly on 560
I think used a copper washer , sorry,  don’t remember where I got it , McMaster Carr . Help section at autozone , sorry I just don’t remember.
is that a 3/4 bolt ? Don’t remember the size I tried o ring did not work
try Napa
also try the good hardware store with all the drawers might be stocked .
could use nylon washer
Its a washer 304012R1
The engine is listed separately from the tractor in the parts books. Thx-Ace
384532R1   Thanks mmi. That number worked. I looked my parts manual over several times and never found that. After you posted this I went to the shop and found it listed. Now to see if the local dealer can find it. If not, at least I know who has it listed as available.
things and # change   have them back check it is correct, if not over priced even for dealer
Go to your local car parts store they have all sizes of copper washers
most sites/photos are calling those plastic wshr
either way they need to be extra clean seated sq and "snug" not torqued to the moon
They make a conversion for the 282 oil filter. It allows you to use a regular spin on oil filter. Put one on my tractor and I like it. It's been so long ago I can't remember how it attaches but it was not difficult to install.
