Ds Devine Posted February 9, 2020 Share Posted February 9, 2020 I'm intending on restoring a TD6 I recently bought according to the serial number it's a 1942 model. However some parts are missing and need advice on what type of each part is it need apparently there is a lot of variations but I'm a bit of a newbie! Parts namely. *Starter motor *Dyno *Manetto Any help much appreciated! Quote Link to comment Share on other sites More sharing options...
sugarmaker Posted February 17, 2020 Share Posted February 17, 2020 Morning, You might get some more comments if you posted in the construction section. Yes you need some parts. They are out there. There is a salvage yard with a TD6 near Pittsburgh, closer to Zelienople. Burg Implement. Try them. Good luck with your project. Regards, Chris Quote Link to comment Share on other sites More sharing options...
7288cdn Posted February 18, 2020 Share Posted February 18, 2020 By the looks of your intake port you may have a seized engine or at least stuck valves. Do you need the manifold and carb or did you take those off? I have those two parts but since you call it a "dyno" I suspect you are in England in which case freight will raise it's ugly head. If you do have a seized engine do a lot of research on the internal condition before you spend any money. I am in mid project on a WD6 (same engine) and internals are getting hard to find which means expensive. Quote Link to comment Share on other sites More sharing options...
