Mr. Plow
New Project - 1/2 Scale IH 60 conser-till plow
New 1/2 scale implement project in the works.  A Cub cadet sized version of an IH 60 Conser Till.  Red Bibs Bill has a perfectly restored example in the attached video.
Planning on 45-48" width with 5 shanks (11-12" spacing) and 7 coulters (6" spacing).  Have operators/set-up manual on the way.  Ordered parts last week, 5ea. 3/8" thick 16" cultivator shanks with points, 7ea. 13" diameter coulters, and 10ea. cultivator springs to duplicate the spring cushion shanks.  Picking up wheels and rims this PM (16x4.00x8).  Once they are all here I'll start drawing/laying it out.  Hope to have it done for the summer shows.
Will make a nice companion to the 1/2 scale 520 semi-mount plow and 370 5' disk!
I saw your disk and talked to you at RPRU in Iowa.  If it turns out like your disk it will be an awesome toy/tool.
Thanks,  I enjoyed talking with you up in IA!  It was nice to see your sand trap rake in person......extra rare attachment!!!!!
That’s fun. Let us know how the process goes!
Ahhhh the infamous sand trap rake! Sweet attachment
Another very cool project.  Can not wait to see it come together. Your shed is full of such interesting toys,.....errrrr equipment!  I know already it will look slkck behind the Cub
A little ACAD to help the process along...
Getting lift geometry right can be tricky....
Ahhhhh plan is in FULL swing now!
Ok, I think it’s update time!!!!🤔🤔
Patience is a virtue......
I ordered tires and need to do some calcs on the lift geometry before I can order the cylinder.
Work has been busy and I have some travel coming up, so it will be a little while before the welder comes out.....but we'll get there!
I have found it goes much easier on these projects if you get the details planned out first.....saves lots of rework!
Tires showed up....4.00x8 Deestone tri ribs
  • Sad 1
Nice. I scored a set of 26-12-12 Goodyears. Those might go well with them.
More progress.  It's just about right.  Second drawing set is for lift and turn clearance. Yellow are tillage parts, red frame,  blue lift linkages. Over all width 48", with 5 shanks on 10.5" spacings.
Look'n good!
Oh, nice!!!  Can't wait to see them in action
Put in steel order today......
'Fraid not. To far gone to use. What I get for breaking my no used tire rule. But I liked the look enough to go with Deestones.
16 hours ago, Mr. Plow said:
Ahhhhhh progress!!!!  Can't wait to see build start to take place.  So you lucky enough to have heated shop to work on this?  Or you have to choose the nicer days to work on it?
Heated garage...but cant leave things out forever,  wife likes the car inside........going to start making small piece parts, then tie into the frame.  First up is all the shank brackets and springs.
Steve.   The weather is starting to warm up.   Just start it for her on the cold mornings!  Lol
Very good point!  Might even get ya brownie points too!
1/2 scale shank assembly....
Frame mock up....cut to length.
