Rs3480 45 Posted January 9, 2020 Share Posted January 9, 2020 Had a 5 shank ripper hooked to 3788, arms kept jumping up with draft set heavy, wat can I do to keep plow in the ground Quote Link to post Share on other sites
pete23 528 Posted January 9, 2020 Share Posted January 9, 2020 Check the adjustment of the draft control. With no load on hitch, position control lever forward to fully lowering of hitch, pull draft control lever and hitch should not raise until lever is about and inch from the top end of slot. Might be as simple as adjustment on the lever it's self or can be internal adjustment was not set after some work had been done on hitch . Quote Link to post Share on other sites
Rs3480 45 Posted January 9, 2020 Author Share Posted January 9, 2020 Will try that, thanks. Wonder if there is a way to bypass or cut off draft? Quote Link to post Share on other sites
pete23 528 Posted January 9, 2020 Share Posted January 9, 2020 3 hours ago, Rs3480 said: Will try that, thanks. Wonder if there is a way to bypass or cut off draft? Well, you can turn those two adjusting bolts, one on each side, so they contact tractor frame and not allow the torsion bar to twist. They are I believe 15/16 headed short bolts that limit the amount of twist . Quote Link to post Share on other sites
Rs3480 45 Posted January 9, 2020 Author Share Posted January 9, 2020 That worked thanks Quote Link to post Share on other sites
