macory
8930 hydraulic leak help
Our 8930 has a hydraulic leak coming from behind the batteries. I took the cover off and found the leak but I'm not sure exactly what I'm looking at. It's something mounted to side of transmission housing. It looks like a couple of accumulators coming out towards the front of machine. I'm trying to look it up to see if there is a gasket or seal that could be bad but no luck. I've looked through the entire hydraulic section on case parts twice now. Any help on what I should be looking for would be greatly appreciated. Thanks!
You are looking at the transmission control valve. Parts breakdown shown in section 6
Thanks, I really appreciate it!
Does anyone have any experience in removing one of these? Can it be removed as an assembly and a new gasket installed or is it a much more technical job than that?
