Any one selling a 60 series scout with a V-8?
That would be an 80.  800 after that and Scout II after that. Not sure what years they changed series number.  Eason or Howard P can give you the specifics.
Dennis
7 hours ago, td9inidaho said:
No expert here, but not sure they came with a v8.
Then again there's always someone dropping them in project scouts for fun😁😁
The 800’s did .
Lorenzo, If no luck here, Head over to Binderplanet , keep an eye on the classifieds, The 80 and 800's ( especially with V8's) are pretty darn hot
right now
The Scout 80 was the model from 1961 to 64, all 4-152 engines
The Scout 800 came out in 1965, still 4-152.
The 4-152 was replaced with the 4-196 in 1966
The V-266 became an option in 1967
The Model 800A was the 1969 model with the V-304 the optional V-8.  The 6-232 from AMC was also an option.
No further engine changes until the Scout II in 1971 offered the V-345 as an additional option,
right now
Thanks, she is already on Binderplanet,
14 hours ago, lorenzo said:
The 800’s did .
Untill she got interested in them I didn’t know a scout from a hole in the wall .
I guess the 800A is a V-8
I have tried to cut down on addiction of chasing across the whole world ( literally ) to come up with projects and parts .
I spent five long years and made several trips overseas once while restoring an antique motorcycle that to this day only three are known to exist . It wore me out.
I never expanded my interest into the scouts and am not real sure I want to open up this can of worms . She is looking at projects and she can see past all the ugly but all I see lately is rust, missing parts, stuck motors, wrong or aftermarket parts, $$$$$$$$  ect   ect
Im trying to talk her into just getting one that’s already done.
I put a 304 in a '61 Scout, used the four-banger bellhousing and drilled the transmission bolt holes to twist the engine uptight, and drilled the flywheel for the smaller clutch. I moved the axles to the bottom of the springs, and dropped the engine about 4" to reduce the U-joint angles. Power steering out of the donor Travellall completed the rebuild. Drove it for years! Cold little bugger in the winter though, couldn't rob a big-enough heater for it! The single-ply tin roof was covered in frost all the time.
A kid living here stumbled on to a early one with a V8. It was 2001-3 had a 66 Ford pickup that was a show truck he had built. Just stumbled up a old running Scout with a V8. Then found it was a really rear Scout, he did the foot work to prove it was original. I don't know if he ever fixed it as he had gotten married just before he found it. Moved out of the area don't know what happened to the Scout.
FYI, 80 series had only the slant-4 engine, V8's came in '67 800's. They also had a 232 cube Rambler-sourced 6. My old Scout 80 had the sliding windows and short cab. I wish I still had it!
I own one of the first diesel Scouts sold in Northeast Nebraska.  It is an automatic with a locking 3.54 rearend and rather gutless.  When looking at the line setting ticket, it was spec'd as a 345 V8 engine with the V8 having a line drawn through it and the word "diesel" handwritten beside it.  Also, the engine code for the V8 is a "2" which was struck out and the diesel code "3" written beside it.  The Scout also came with the trailer tow 2" receiver hitch factory mounted.
I had a 77 scout II diesel auto. A strong headwind would slow it down. Didn't have enough power to get stuck.(wouldn't spin the wheels)
  • Sad 1
Consumer Reports tested a diesel before the turbo version it had one of  the slowest 0 to 60 times of any vehicle they had ever tested, in line with the Subaru 360 2 stroke car.
I really wanted a new one  in 1976 model year but the $11,000 asking price was about the same price of a Cadillac  car.
I was in Seattle for Calendar year 1982. Local low-end used car lot had a 64 152 Scout that I test drove more than once.  It started and ran and was not rusted out believe he wanted $375. for it BUT that was in 1983. Believe it was a 3 speed with 2 speed transfer case.  In low/low it would bury the tires on a hill side I played on.  I already had too many toys so common sense and a family said NO. My borrow a toy was sold to someone else.
  • Confused 1
