jass1660 2,271 Posted June 3, 2020 Share Posted June 3, 2020 16 hours ago, sandhiller said: Agreed. Have one behind a N-14 Red Top, comes in a close second behind a 13sp IMHO. Depends on where you live I guess. In my hills the 13 - 12 shift fits better than the 10 - 9 rpm drop. Shifting it confused too many guys, that trans was only around a few years. 1 Quote Link to post Share on other sites
IH OAK 70 Posted June 9, 2020 Author Share Posted June 9, 2020 Was there any connection between Ford's trucks and IH's Travelette? Or the Ford Caryall and IH's Travelall? How about the Scout and Bronco?? They just look similar to me. Quote Link to post Share on other sites
Howard_P 151 Posted June 10, 2020 Share Posted June 10, 2020 No connection. IH had each of those first and when Ford wanted a piece of the action, they didn't stray too far from what was similar. Of course, GM's designs are also similar, except they went a different direction with the larger Blazer. 1 Quote Link to post Share on other sites
IH OAK 70 Posted July 17, 2020 Author Share Posted July 17, 2020 I was looking for engines and parts on eBay and came across a DV-573. I didn't know such a thing existed. I assume that it was a lot smaller than the DV-800. We're they more common? What were they put in? Quote Link to post Share on other sites
IH OAK 70 Posted July 18, 2020 Author Share Posted July 18, 2020 Did they make 2 ton travelettes? Quote Link to post Share on other sites
DWF 57 Posted July 18, 2020 Share Posted July 18, 2020 Quite a few DVT-573's ended up in construction equipment like TD20-C and 250-C crawlers. Some in Hough loaders too. I don't know much about S-series trucks. On a side note, don't let JMech get to you, he's a real pain. A few weeks ago he said he would no longer read your posts, but look what happened. Good luck with the TD9, things will get done in time. If you run in to what seems like a dead end, stop working on it for a while, then usually it will work out better. DWF 1 Quote Link to post Share on other sites
1480x3 455 Posted July 18, 2020 Share Posted July 18, 2020 On 5/27/2020 at 6:07 PM, Jeff-C-IL said: IL, 1H, 2L, 2H.....you're essentially talking about a Super 10 road ranger tranny. (yes, you can skip shift under light loads). The Super 10 is a great transmission, easy to shift, don't have to row as much, easy to skip every other gear.....UNLESS you can't switch your mind from the regular pattern. Some guys love them, some hate them. It just shifts different...timing is slightly off. If you want one of those trannys with all 10 speeds, just go to a local truck junkyard...likely mate right up! I had two trucks, a '95 White/Volvo with a S-10, and a '97 White/Volvo with a regular 9 speed. Sitting in the truck they look similar. You had to REALLY think which one you were in, and not start flipping the high/ low lever at the wrong time! The S-10, with a light load, I'd often start in 3rd, and go 3rd, 5th, 7th, 9th, 10th. 3 shifter moves, one lever flip. You didn't want to go 8-10, too big a gap. The tractor pictured above was my 4386....that was just a standard 10 speed. I wouldn't have wanted to drive it 26mph on the road, 20 was plenty fast, they could start shaking. Pulled a tow between with dolly wheels for a while, if the dollys started whipping you could find yourself in the other lane real quick! One time there was a little ice on the road....glad there was a ditch to catch the tires.... A 4x4 doesn't steer like a MFD or 2wd....fast can be scary! First time I ever drove a super 10 was a 9400, N-14 of my buddies. He asked me to bring his truck to the fld for him. It was night and no interior cab lights worked. All he said was it was a 10 speed and I had only drove 9 & 13 speeds. Can't believe I didn't tear something up, finally found a gear it would go about 40 in and made it to the field, 5 or 6 mile. stopped, put it in 1st [ only gear I was sort of sure about ] drove it in field. Buddies laughing as he starts in "oh, I forgot to tell you - - - - " Quote Link to post Share on other sites
Howard_P 151 Posted July 20, 2020 Share Posted July 20, 2020 On 7/17/2020 at 9:01 PM, IH OAK said: Did they make 2 ton travelettes? No. The one-ton 1300 models were the largest. But there were Loadstar Crew Cabs which offered 6 passenger capability, but not as a pickup unless you made your own. 1 Quote Link to post Share on other sites
IH OAK 70 Posted July 20, 2020 Author Share Posted July 20, 2020 14 hours ago, Howard_P said: No. The one-ton 1300 models were the largest. But there were Loadstar Crew Cabs which offered 6 passenger capability, but not as a pickup unless you made your own. Are the fenders etc. interchangeable like the dentsides Ford 2-tons? Quote Link to post Share on other sites
Howard_P 151 Posted July 21, 2020 Share Posted July 21, 2020 7 hours ago, IH OAK said: Are the fenders etc. interchangeable like the dentsides Ford 2-tons? Do you mean from a Travelette to a Loadstar? No way, completely different trucks. 1 Quote Link to post Share on other sites
IH OAK 70 Posted July 21, 2020 Author Share Posted July 21, 2020 13 hours ago, Howard_P said: Do you mean from a Travelette to a Loadstar? No way, completely different trucks. So they didn't use the same cab on a heavier frame? 1 Quote Link to post Share on other sites
Howard_P 151 Posted July 22, 2020 Share Posted July 22, 2020 You specifically said fenders which won't interchange. The basic cabs are the same, but I think I've read there may be some minor differences, but I'm not familiar with what they are. 1 Quote Link to post Share on other sites
IH OAK 70 Posted July 22, 2020 Author Share Posted July 22, 2020 On 6/2/2020 at 1:53 PM, Jeff-C-IL said: That silver/chrome truck above is a work of art. Do you have a year on that? Gorgeous. It is for sale.....http://topclassiccarsforsale.com/international-harvester/419404-extremely-rare-1966-international-travelette-1200-series-factory-34-ton-4x4.html There are tons more for sale on that site including this red one. Quote Link to post Share on other sites
IH OAK 70 Posted August 11, 2020 Author Share Posted August 11, 2020 I recon I am now looking for a crewcab Loadstar. Would a DV-800 fit in a Loadstar without a lot of modification to the truck? I am planning on putting on a pickup front end because I like the looks better. Quote Link to post Share on other sites
jass1660 2,271 Posted August 11, 2020 Share Posted August 11, 2020 1 hour ago, IH OAK said: I recon I am now looking for a crewcab Loadstar. Would a DV-800 fit in a Loadstar without a lot of modification to the truck? I am planning on putting on a pickup front end because I like the looks better. It is a massive engine compared to what a Loadstar is...... 1 Quote Link to post Share on other sites
IH OAK 70 Posted October 28, 2020 Author Share Posted October 28, 2020 Howdy Guys, I'm back. I think I am pretty set on either the '61/'62, or '63/'67 body styles. Here are: 61, 62, 63, and 67, Were the Loadstar/Travelette cabs interchangeable for these years? Quote Link to post Share on other sites
R Pope 279 Posted October 28, 2020 Share Posted October 28, 2020 Loadstar cab is different in the cowl ahead of the windshield. It drops down to the hood where the pickups go straight ahead. The transmission in my 4586 has got all ten speeds in it. It will go into fifth only if the range lever is in low. Try going from 9 to 10 and the lever won't go past neutral. Put it in 5th and pull the hi-low lever to Hi and the shifter comes out of 5th. 1 Quote Link to post Share on other sites
IH OAK 70 Posted October 28, 2020 Author Share Posted October 28, 2020 13 hours ago, R Pope said: Loadstar cab is different in the cowl ahead of the windshield. It drops down to the hood where the pickups go straight ahead. So in order to do something like this I would have to do a cab swap?? I couldn't just change the hood, fenders, grill, etc. and make a loadstar look like a pickup?? Quote Link to post Share on other sites
IH OAK 70 Posted October 28, 2020 Author Share Posted October 28, 2020 12 minutes ago, IH OAK said: So in order to do something like this I would have to do a cab swap?? I couldn't just change the hood, fenders, grill, etc. and make a loadstar look like a pickup?? Or more like this. Quote Link to post Share on other sites
jass1660 2,271 Posted October 28, 2020 Share Posted October 28, 2020 With unlimited funds and time you can do anything Otherwise it’s pretty stupid to attempt 3 Quote Link to post Share on other sites
hillman 664 Posted October 28, 2020 Share Posted October 28, 2020 30 minutes ago, jass1660 said: With unlimited funds and time you can do anything Otherwise it’s pretty stupid to attempt unlimited 1 Quote Link to post Share on other sites
IH OAK 70 Posted January 26 Author Share Posted January 26 Okay this thread has been dead for awhile, but I had some questions. In reading on the forum IIRC the DV-800 seemed to have been developed for trucks, didn't get too much success, went to scrapers, performed well at 1900 RPM, went to tractors and they wanted more power so instead of running at 1900-2100 and turning up the pump, they turned up the governor and they got problems. Correct me cause I'm sure I got something wrong. Anyhow, when I do this build, I am thinking to do a titanium crank and maybe cam, could I turn up the pump and turn down the gov. and get the same power with better lifespan? What was the maximum boost they could handle? Did they ever put Jake Brakes on them? Thanks. 3 Quote Link to post Share on other sites
Mudfly 276 Posted January 26 Share Posted January 26 1 hour ago, IH OAK said: Okay this thread has been dead for awhile, but I had some questions. In reading on the forum IIRC the DV-800 seemed to have been developed for trucks, didn't get too much success, went to scrapers, performed well at 1900 RPM, went to tractors and they wanted more power so instead of running at 1900-2100 and turning up the pump, they turned up the governor and they got problems. Correct me cause I'm sure I got something wrong. Anyhow, when I do this build, I am thinking to do a titanium crank and maybe cam, could I turn up the pump and turn down the gov. and get the same power with better lifespan? What was the maximum boost they could handle? Did they ever put Jake Brakes on them? Thanks. Titanium crank? Just for asking what would a custom made titanium crank cost? I think you would be better served to get a good running engine to start with and not mess with custom parts. 2 Quote Link to post Share on other sites
J-Mech 1,489 Posted January 26 Share Posted January 26 1 hour ago, IH OAK said: Anyhow, when I do this build, I am thinking to do a titanium crank and maybe cam 2 1 Quote Link to post Share on other sites
Farmall 1466 51 Posted January 27 Share Posted January 27 18 hours ago, IH OAK said: Okay this thread has been dead for awhile, but I had some questions. In reading on the forum IIRC the DV-800 seemed to have been developed for trucks, didn't get too much success, went to scrapers, performed well at 1900 RPM, went to tractors and they wanted more power so instead of running at 1900-2100 and turning up the pump, they turned up the governor and they got problems. Correct me cause I'm sure I got something wrong. Anyhow, when I do this build, I am thinking to do a titanium crank and maybe cam, could I turn up the pump and turn down the gov. and get the same power with better lifespan? What was the maximum boost they could handle? Did they ever put Jake Brakes on them? Thanks. You must have found the gold at the end of the rainbow... 1 Quote Link to post Share on other sites
