Driver1
N-14 celect+ misses on acceceration
1998 IH 9400, n-14 celect+ misses intermittenly on accereration. Since the first of October when this problem started , we killed the algea in the fuel system and ran several tanks of fuel to clean it
out, we had the overhead ran,replaced the plugs to theECM,replaced the ECM,thought it might be sucking air ,replaced all the fuel lines ftom tanks to pump, When you do a injector cut out test you can't
pick out a bad injector,no check engine light no codes on ECM.. I got it in a different shop now, they are stumped, Any body got any suggestions.Thanks   John  PS the ECMcooler plate is bypassed.
Not sure if it is the same situation or not but we just had one that would run poorly at about 1700 RPM and up.  It was debris in the check valve on cooler plate.
We found the problem. Number 1 &4 injestors were missing intermittenly.
