repairing the 3 poingt shaft 1466?
4 hours ago, pt756 said:
hello so the shaft where the 3 point arms mount on I think needs to be replaced on the 1466. don't you have to reach around inside thru the top link to work on this, there must be seals and I was wondering cost.
the sensing arm needs to be removed to slide the lower torque tube out of the rear frame and yes it can be removed either thru the third link cover I always pulled the pto out  made it alot easier not sure why you need to replace it usually just seals or bushings is all is required
Right side should be solid, left side is the one is the one that comes off. Sounds like you might need new bushings. Not a hard job but aggravating.
