TX1206
1206 fuel/temp cluster wiring
I am new here and appreciate your help. I am replacing the original gauge cluster which has 2 wire posts vrs the new one that has 3. The new one appears to have “ “sender”, “negative” and “ignition” posts. I have not done much wiring so I am not familiar with how this should go.
Welcome aboard!
The ignition and sender studs should be insulated from the cluster metal housing.
ignition is the 12 volt power wire coming from the key switch.
sender is the wire to the sender unit in the top of fuel tank.
you don’t need the negative if the bracket grounds the cluster to the dash but if the light doesn’t work you can run a grounding wire to that negative terminal.
clear as mud?
good luck
