Dale, pirlbeck.....JD Quad Range clutch pressures.
TP from Central PA
Posted
Was asked by a friend to look at a 4230, it didn't/doesn't move, even though I am done with the shop I told them I would since they don't need it until next spring and when its fixed I can use it until then.  Anyhow, put gauge on the clutch pressure port, had maybe 120 at idle, no change at higher rpms.  Everything else seems to work ok.  I believe the spec at idle is 165'ish and it climbs to the 180 neighborhood if my memory is right?  I know the spool can be shimmed to bring up pressure, but that is a bit too much for me as I believe the shims are for 5 psi at a time, and I assume there is a issue elsewhere.  I threw a filter in it, old one was ok, I am thinking the other screen in the rear might need looked at, but was wondering if there is a port there I can test that pressure first?  Appears there is, but not sure which one?  I took the spools out, polished them, cleaned and installed, springs and everythign else looked great. Anything else I should be looking at?  This is the first time I have monkeyed with troubleshooting a quad range.
Posted
Don’t have a book handy . But 180 sounds right. Those clutches are designed to slip before they burn everything up. Clean the transmission screen. Then start tractor make sure trans light goes out and doesn’t blink at idle. The trans pump provides clutch operating pressure. So if low that is what’s usually wrong. Pipes crack internally or hard orings. I did have a early 4430   clutch that went out 2times on me. It was fixed shortly before I did it. It had the extra thermostatic valve and line added as early ones needed. The previous guys flipped valve around and tractor had no lube pressure. Never pumped oil to cool clutch flipped it around never had trouble since. I would say you need to check trans pump though.
Posted
Here is picture of trans pump usually gives you trouble. But clutch is shot also if it quit moving pull the 2 speed and go through that also you have to drill out orifice on front pipe if you change pumps they are spendy and big one is all you get now.
Posted
Screen is next on my list.............Is there a port on the outside of the case I can plug into with my gauge to see what pressure I have at the pump itself?  This is a dairy tractor so its lucky to have a hood, so the dash working properly is out of the question.  Doesn't matter what side of the 2 spd, doesn't work.  In A range in first it trys to move, but of-course pressure is too low so it doesn't, but I don't think any of the other components are the issues with that in mind.
Posted
I had a 4840 power shift I was working on doing the power shift version of these symptoms.  We used a flow rater in the line going from the traction clutch valve to the front pump.  The front pump on that one was starving for oil making noise so we knew we had a flow problem.  The transmission pump end up solving the problem.  This might not be super helpful but I thought I would mention it.
Posted
No I don’t think there is a specific place other than the spots on clutch valve to check pressures. You could always pull sender for light it is on back by filter and screw a gauge in there. The dash light will flash at idle when warm then you know something’s wrong in back.
Posted
Those power shifts can give you fits sometimes. There is a procedure in the book to do like you did. Then destroke pump to see where oil is going.
Posted
sounds like a problem in the C1 clutch pack that's the clutch pack that engages the transmission probably needs resealed  and also could be an issue with the pressure tubes going to the clutch pack and pto clutch they are behind the clutch valve on the left side there's O-rings on all three tubes also you can do a air pressure test to see if you hear the C1 clutch engaging or hear a leak
Posted
Usually the 2 speed works in one or the other hi or lo. Usually loose low first .,When you split it it is easy to remove hi lo planetary to go through it right away.
Posted
I've seen the bolts break and work out of the C1 clutch pack   housing and when they slide out far enough they break off the pressure tubes another thought is the differential cross shaft or gears broken may not be a clutch pressure problem at all early 30 series were prone to that then Deere updated the differentials to four pinion spider gears instead of two
Posted
Yes forgot about spider pin coming out. That happened years ago on neighbors 1586 dealer but clutch and ta in still no go the spider pin broke.  Usually the 4230 4430 aren’t souped up to break stuff the brakes wear screwing everything up. Fixed a 4230 last year back top shaft bearing went bad and ruined trans pump.
Posted
O ring number 7 on trans bottom outlet check valve is always rock hard and deteriorated. It is bugger to change in their with ring gear in place but can be done. You can check trans pump flow but good guideline is if light flashes at idle when warm. It will need 3 pt cover pulled and pump changed then split it do all clutch seals and hi low. The trans pump is just something that goes bad on them like a ta pump on a IHC you can pull cover with removing cab if you make a lift handle.
Posted
He's stating 120 psi at idle that should be enough pressure to at least move the tractor no mention of hours I'm assuming high hours the pump may be getting weak from wear
Posted
I don’t know if this will help but a old timer once showed me to lower the three point hitch all the way then raise it while turning the steering wheel if the lift doesn’t move or is jumpy while trying to lift up and turning wheel back n forth most times the supply pump is bad or weak steering has priority
Posted
Yeah, I think that is what I will do, I seen it there, thought maybe they put a port somewhere I wasn't seeing. I would like to see what it is before I check the sump screen.
Posted
There is the filter relief on back also you should check. Just my experience with those is clutch usually doesn’t quit moving they are designed to slip if adjusted right when at end of life. But I have done this also if you give nuts an additional 1/2 turn past adj they will go until clutch discs are gone. You need special tool to adj those clutches to.
Posted
Only way you can adjust the clutch fingers on those using JD tool is when its split and then its to keeps the fingers adjusted to the same height same for PTO
Posted
On our 8630s and all the other tractors if clutch is together you can spin the nuts carefully 1/2 a turn. Like if you pull an engine and clutch housing oil was clean and trying to look at plates and they appeared okay without dissembling. This is only for adjusted already clutches. But this gets into to tight and burning the plates all up. We have the jd tool to adjust them except not the 4wd one. We used to just have dealer adj the odd 4wd clutch we needed. Over the years we have figured out how make or buy the JD service tools for up to the 50 series
Posted
TP ,
Sorry, but I just seen this post....I don't come to the coffee shop on a regular basis.
I show clutch system pressure for a 4230 as being 135-145PSI @1900 RPM, so you are not as low as you think you are. Did the problem start as a clutch slipping under load? Do you know how long the problem has been there.........while we usually see the perma-clutch tractors when the clutch is just slipping, but will still move, due to the fingers bottoming on the clutch cover it does not take long for them to wear enough to not move at all after they start slipping.  You might try engaging the diff lock just to see if that may make a difference and eliminate a diff or axle wedge problem.
I think you are going to end up splitting it and replacing the clutch and as Dale mentioned we always pull the 2 speed and check it out when the tractor is split.
If this is an early tractor with the manual bypass valve for single acting cylinders be sure it is closed or if left open it will short the lube circuit of oil and cause short clutch life. Also we always update the 2 speed brake piston to the later style with the holes in it to help apply the piston seal. You can add the holes to the early piston, but you almost have to see one to know how to do it.
Posted
I was told they backed up to the silage blower, and when they were done it wouldn't move?  They towed it in a shed and it has sat a few years.  I will find out for sure. I didn't try the diff lock, but will after I clean the sump screen, also going to plug in a gage at the sensor port and see what that is showing, I don't believe much if anything on the dash works.  I am just tinkering on it when I have free time, trying to get my junk all cleaned up and put away for the winter.
Posted
Pulled the sump screen today...............full of crap from the clutch I assume because the brakes were done a year or two before it quit moving.  Clutch pressure didn't change, but the flow must have, because it moved in A1 and R1 in A range, but the clutch is definitely slipping so it will need split.  You guys have the tool to set them up?  I was wondering if I could get measurements to make one?
Posted
I will post a pic you have to buy the tool to complicated to make. You can take flywheel and clutch to Deere dealer have them set it and you can take assembly home and put it together ..  will post pics of tool tomorrow and some instructions.when you pull 2 speed you can hook back shaft and pull it through then lift planetary out instead of pulling pto gear out. When we bought our tool years it was 600 already. Here is pic of what you need to adjust. Price is more now
Posted
Yeah, looked at it this morning,  with the mill, lathe and surface grinder, I am sure I could copy it with enough info.  With the new regime in the green dealer, I am sure adjusting wouldn't be cheap, if they would even do that, probably would want it start to finish. They did one in a 8640 years ago when I had the 619 out, and that wasn't cheap.
Posted
Forget you have access to machine tools what measurements do yo need all of them?  I will measure ours tomorrow and see if I can post some schematics.
