glenn k
CX 80 transmission safety switches
Have a CX 80 has bad safety switch,
2 switches side by side under cover (244024A1) feeds thru both switches to the starter relay. I install a new clutch switch (280925A1) in the upper threaded hole in clutch pedal bracket and by-pass the ones in transmission as they last about as long as it takes to get home with them. By doing this you have to have clutch depressed to start engine.
How do you bypass the switches?
Thanks
Glenn
I fought this problem on a customer’s tractor quite a while back. I ended up mounting and wiring in a switch that requires depressing the clutch pedal to start. The OEM switches are a joke.
