Gearclash
06-86 Driveline Question
What does the forward transmission housing of the IH hydro tractors (like a 186) look like?  Do they have the same pto gear arrangement?  Cover under the pto gear?
I think the 66 series and up run the dry bolster up front. You could have a machinist bore a hole through the front bolster and you could run something off the front of the engine crank shaft.
Here's a picture of a hydro
Okay, a question about the hydro anatomy.  I see the hydro trans appears to have the same bolt on cover on the bottom.  Are those mounts for what I am assuming are the hydro and motor servos mounted to that plate or are they part of the case?
Guys I realize that this is a  "Red"  forum,  and I love the old red tractors/equipment.
But,  there may just come a time when a person needs to buy a John Deere 3010-4020.......they came from the factory with a front PTO shaft.
When I was a kid we had a Deere 50 front mount mower (driven with the front PTO) and a New Idea hay conditioner hooked to the rear of a 4020.....it worked fine.
No room in the feed alley for one of these?
4320 and I think the big ones 45/46 had front pto. A 4320 would be what you need. I completely forgot about these.
What RPM did that front PTO spin at?  1000?  Engine speed?  Was it independent of the rear PTO?
I'm pretty sure it was a 1000,  and it was not independent of the rear.
No green tractors for me . . . not that I think they are junk, they’re not for the most part. I like to have as much commonality as possible in what little equipment I have.  If I were to go with a tractor that had a factory front PTO, I would find another MX Maxxum.  I will have to evaluate the Bi-Di as a possibility though.
