Hojon 2 Posted October 20, 2019 Share Posted October 20, 2019 (edited) People in and on the topic talk about the rod and cup, clean and replace or put back in after . Is this with the pump off or is it still connected to the motor. They mention a rack, is it behind the "A" cover of the pump? Is that where the plungers are ? Get lots of white smoke and engine dies trying to go to diesel. That's from to much fuel ? Forgot to say thanks. Thank You . Edited October 20, 2019 by Hojon for got to thank ahead. Quote Link to post Share on other sites
mmi 360 Posted October 20, 2019 Share Posted October 20, 2019 if you have good pump pressure on gas,system is bleed and otherwise good flow of clean fresh fuel add 2 qt of atf and let cycle on gas run for 10 min on gas first then I would suspect starting valve/s stuck flipper hanging Quote Link to post Share on other sites
