patricksjohndeeres 6 Posted September 26, 2019 Share Posted September 26, 2019 Have a 1256 and it had been sitting for some time, it starts right up and I haver used it around yard a few times, no issues,, yesterday went to use it and started nice ran for about 10 min then powered down and stopped, tried to start again fired up but again powered down. I read the posts that is maybe be return top fuel fitting the issue, I cleaned it and drilled it out and still the same issue... If I loosen the side screws on the small flat plate fuel will spray out and the engine will stay running. the min i turn them tight she stops running.. What could be the issue ? Thanks for any help Quote Link to post Share on other sites
J-Mech 1,176 Posted September 26, 2019 Share Posted September 26, 2019 Return line is plugged, or pinched shut. Take it all apart and clean it out. Quote Link to post Share on other sites
Injpumped 250 Posted September 26, 2019 Share Posted September 26, 2019 Time for proper pump servicing. As J said, the return tract beyond the pump is likely plugged with broken down flex ring material. Very common to have that happen after these have been sitting for an extended period of time. 2 Quote Link to post Share on other sites
snoshoe 400 Posted September 26, 2019 Share Posted September 26, 2019 I think your working with wrong fitting. You drilled out a glass ball?? If it won't run with return line unhooked. The check valve is plugged and pump needs service. If it runs with line unhooked then problem is with line Quote Link to post Share on other sites
patricksjohndeeres 6 Posted September 26, 2019 Author Share Posted September 26, 2019 I blew the return line out to the tank nothing in it. I never tried to run it with the line off , I drilled out the bottom little part of the fitting and put it back together and tried it .. Quote Link to post Share on other sites
Diesel Doctor 2,091 Posted September 26, 2019 Share Posted September 26, 2019 With he engine running and all fittings removed from the pump, it should run and dribble fuel out the top of the pump. Then start putting fittings back in unit it stops or all the return lines are hooked back up again. The very top fitting in the pump has a check ball in it that looks like glass. May be plastic. If using air to blow that clean, you need to use a needle, etc to move that ball off it's seat to get air to go through the fitting one way. Fuel will flow one way, from the pump to the tank unless that fitting is plugged. The ball stops fuel from flowing back into the pump from the return. That fitting will be packed full of like a very fine black sand. That was originally a clear or tan piece of plastic that held the governor weight retainer together. The two pieces of the governor weight retainer are now floating around unattached in the pump.The governor does still work and is turning. When replaced, you can use a solid weight retainer that stops this from ever happening again. They say it can effect the governor but I have never seen it. Always remember, a Roosa Master must allow return fuel out the top of the pump against zero pressure. Any pressure builds and it will slow the engine until it quits. The remains of the elastacast ring that holds the governor weight retainer together has disintegrated, plugged the return somewhere and stopped the engine. This is the best place to start. 1 Quote Link to post Share on other sites
snoshoe 400 Posted September 26, 2019 Share Posted September 26, 2019 Still think your working with wrong fitting. Does it screw directly into aluminum pump cover? The fitting should be steel. Quote Link to post Share on other sites
patricksjohndeeres 6 Posted September 26, 2019 Author Share Posted September 26, 2019 that is correct steel fitting on top of pump cover ..I took the return injector line off today as well and blew threw it with air, no blockage there . No blockage to the tank as I blew that out first . Quote Link to post Share on other sites
snoshoe 400 Posted September 27, 2019 Share Posted September 27, 2019 Well you have proved case is under pressure when you loosened side plate. That steel fitting in top pump cover is the escape hatch. If its open and line is open. Hole in cover has to be plugged. Never seen this. Start engine with fitting out. Does fuel dribble out? Quote Link to post Share on other sites
patricksjohndeeres 6 Posted September 28, 2019 Author Share Posted September 28, 2019 took the fitting off and it was blocked , I think the ball in fitting that I drilled threw had turned and closed it off again. I used a piece of wire to put threw it again and put it back together, runs good now,, so I will run it for a while and see it it will do it again ,I will have to drill a bigger hole if it happens again , Thanks for the help Quote Link to post Share on other sites
J-Mech 1,176 Posted September 28, 2019 Share Posted September 28, 2019 You need to replace that fitting. You don't want contaminated fuel flowing backwards into the pump. 1 Quote Link to post Share on other sites
dale560 2,036 Posted September 28, 2019 Share Posted September 28, 2019 It is a nice looking 1256. You should be able to fix the pump and come out well on it or reduce the price some. Let the next owner fix it. Quote Link to post Share on other sites
jass1660 1,968 Posted September 28, 2019 Share Posted September 28, 2019 3 hours ago, patricksjohndeeres said: took the fitting off and it was blocked , I think the ball in fitting that I drilled threw had turned and closed it off again. I used a piece of wire to put threw it again and put it back together, runs good now,, so I will run it for a while and see it it will do it again ,I will have to drill a bigger hole if it happens again , Thanks for the help It won’t run for long like that. Quote Link to post Share on other sites
patricksjohndeeres 6 Posted September 29, 2019 Author Share Posted September 29, 2019 yes need a new fitting for sure, not sure were to get it but will check it out. thanks guys Quote Link to post Share on other sites
J-Mech 1,176 Posted September 29, 2019 Share Posted September 29, 2019 3 hours ago, patricksjohndeeres said: yes need a new fitting for sure, not sure were to get it but will check it out. thanks guys Case IH or any reputable pump/ diesel shop. Quote Link to post Share on other sites
Injpumped 250 Posted September 30, 2019 Share Posted September 30, 2019 don't waste time replacing fitting if you aren't going to get the pump repaired. The problem is inside the pump, not the fitting. The fitting plugging is just the result. Instead of drilling, just remove the ball and spring from the fitting and use it to finish the jobs at hand until it can be down for a few weeks while getting it properly serviced. 3 Quote Link to post Share on other sites
IHFarmer07 1 Posted October 1, 2019 Share Posted October 1, 2019 We had the same issue on a friends tractor, 856, and Ed is right, the flex ring is deteriorating or deteriorated. The tractor ran fine for a bit and then had no throttle, wouldn’t go up in rpms, it first would speed up past 1/2-3/4 throttle then went 1/4-1/2 then nothing. It happens nothing you can do, it’s a roosemaster thing. InjpumpEd is a pump shop and does does great work from what I read......when I have a pump go down I’ll have him work on my pumps. Quote Link to post Share on other sites
