BBB427 Posted September 21, 2019 Share Posted September 21, 2019 I have a 7130 Case IH Magnum I believe it's a 1989 with 2 speed reverse parked it for 2 weeks when I went to move it it would not move after playing with the levers for a while I got to move but the transmission pressure light came on had gauges on the transmission everything seems to be within specs for what the Case IH guy told me tractor works fine if I move the hydraulic remote lever forward so it's under pressure then everything works fine but when you first start the tractor it takes about 30 seconds for the hydraulics to start working right like something's bleeding off if you let it off the transmission pressure light comes back on I do have itisolated the pressure switch on the pump is making it come on anybody had similar problems check valve somewhere any help would be appreciated thank you Link to comment Share on other sites More sharing options...
