560Dennis
Flat ,tubeless bar tire 18x8.5-8 nhs repair
The Kubota front tire is got a leak . I was wondering if a round boot patch on the inside will hold up? The inside surface is very rough .
buff it with wire wheel to prep it
eventually it will get dirt in and push the patch off...........
plug and sealer if it's tubeless
I plugged it now I got bead leaks all around
Scraglycat..........I don't believe I would use a roll model who always has equipment leaning from tires being flat as to what to use to repair flat tires?:blink:
My question here is why not put a tube in it?
I used a plug , for he bead lead I used rustolem rusty primer on rim with brush. The tire irons must have torn up the first paint job , thanks
the plug will obviously work
but I didn't realize you were working on such a small tire, because they have little integrity/strength the plugs will pull out easily
when you get tired of it going flat have it filled with foam......
