Drewu223
How much is too much?
How much boost pressure is considered too much on a "stock" DT414, 436, 466? Mine is pushing a little north of 30-35ish with a maxed out stock pump and S2E turbo. I've heard that 50 is usually the limit before it blows the stock head gasket w/ stock head bolts. Anyone have any input to that?
are you making a puller? what are you trying to accomplish or just trying to see if yours is normal?
I mostly pull it but can turn it back down for farm use if need be. Just kinda curious what other pullers are getting
35 # of boost will not hurt anything in the field or on the track
You will know when it's too much.  If you get much higher I would fire ring it.  The bottom end will hold over 100 psi. Then you would need billet rods and griddle.
