400 series head differences
Drewu223
2 hours ago, RAH said:
Has to do with the swirl of the head. There are a low swirl, moderate swirl, and high swirl.  Naturally aspirated engines generally have high swirl heads.
Yup, H is high swirl for NA engines.  No mark is low swirl for turbo except B and C series engines.+ is intermediate for Turbo B and C series engines.
So would running a turbo with an H head have any advantages over a no mark or + head? Just curious cause I still have the H head on my 966 although it has an S2E turbo
Here's a good story on 400 series heads -back in the mid '70s we bought a 1466 that had been drove over the side of a bridge and broke in two with just 9 hours on it. it sat around for 2 years before it got put back together and in the meantime our IH mechanic noticed cast into the top of the head between 2 injectors was the word ''special'' -he had never seen that before and that tractor always ran better and sounded different than the other 1466's in the area. about 10 years ago we had a young mechanic from the West Liberty Iowa dealership working on my 856 an got to talking about tractor pulling as his family was involved with it. so I told him about the head on the 1466 an he knew exactly what it was....it was a early Hyper-Max casting. Jerry Lagod was an IH engineer and tractor puller an had these special heads cast at IH an this one must have got ''lost'' -so I wonder if this happened more than once or do we have the only 1466 with a ''factory'' Hyper-Max head? An yes we still have it with around 2000 hours on it. also our IH mechanic was Dana Monson from Aledo ILL -the tractor puller. he always wanted to pull it off and see what it was but he claimed he didn't.....I think he knew.
Since the beginning of tractor pulling rules state that you must use factory head. Jerry’s way around that was recasting heads using a ih part number. To this day you can go to your dealer with the part number and have them look it up. It will show up for a 1066, but not available.
SO---the 1466 you have is the "factory" one that made it so his heads were factory......!?
we had a 400 LPGas blew the head gasket out between two center cylinders - block was cracked as well, had to have block welded and then i think the put new sleeves in it with bigger sizes - I was in my teens at the time so only remember bits n pieces - I do know they did head work with some special kind of valves - it ran very good but was a pain in the butt to get started under 35 40 degrees - I think the lp head might have been a little different but not exactly sure
