Motor id help on a td 9
The TD-91 series, last machines with the 4 cylinder motors were a 350 cubic inch engine. Can't tell anything by any of the other numbers as my parts book doesn't go that high. 6 blade fans were an option on the early engines and may have been standard on the later engines. Both of my TD-91s have 6 blade fans, one a pusher and one a puller.
George
The machine is a 52 serial number, some one has changed the motors and also new rollers,idlers and sprocket. My guess they did a undercarriage change then the motor went out. They couldn't get all the gas/diesel levers right so took it for scrap and we ended up with it.
George
George, curious to know if both your TD-91s have the same starter set up as Dome has, with the solenoid on the bottom side of the starter ??
My td9 has the 350 motor as it should. Starter has solenoid on top, is it possible they clocked the nose piece on the starter quarter turn?  Can't remember when I rebuilt the motor if they starter had 2 or 4 bolts holding it together
Mark
