1966 1200 Factory LP Flat bed.
8 minutes ago, exSW said:
Love that style. Back in the '80's those were the ones. A step up from white spokes. But unless the metalurgy has improved I wouldn't use them on a work/towing truck. A set of deep dish steelies that would take the IH dog dish hub caps would be my vote. Stockton wheel still around?
I was thinking along the same lines. I think there are some stock looking steel wheels for some companies that are just a larger diameter to accommodate more modern tire sizes. The addition of a factory style hub cap would be pretty cool on an 18-20” factory looking steel wheel.
As far as I know Stockton has merged with some big supplier that no longer makes custom wheels !
tried to have deep dish steelies made
the shop tried finding a source also .
the good thing about these is they are very reasonable so if I find something I really want I can get another set .
as oppose to the RedKid those wheels were custom made for it ! No changing unless I want to spend big money and I am loosing my appetite for that lol .
tony
I am looking ! But to keep moving on we are starting out with the indys , hopefully there will be something that melts my butter come along.
if you look at the original before pic , I believe Herb made those rear wheels himself , I like them but cannot use hub cap , even the front ones don’t take period correct hub cap .
Tony
tony
There was a factory GM deep dish but the center hole was to small to fit over a nonGM hub(at least Ford and Dodge).
8 hours ago, redturbo said:
Classic 5 spoke will look great on that old work truck.  I see your engine has nice IH America aluminum valve covers,  are they getting polished?  The radiator looks awesome all polished up,  how long does that shine stay?
I will look into it , thanks .
yes I plan to polish them when we begin final assembly.
I have polished tanks on my other pick up and so far it’s been polished several years just need little TLC once twice a year .
I learned about that brass under paint that older IH’s had from my LP equipment on the SMTA & 806 LP under all that red paint was beautiful metals that could be polished .Not to mention the hydraulic pumps on the 400,300u ,SMTA they buff out great , then clear coat and they look new for long time .
both my truck’s tanks were painted black I happen to scratch one on other truck and walla beautiful brass under that ugly black . On both trucks I had old tanks polished and made sure buffer left the IH parts tag on them , they both have original buffed tanks top and bottom with new cores .If we seal it with clear coat it holds the shine much longer , I have not done it on the trucks but I now do it on all my LP buffed equipment including new Havac lines used , I have them lightly blasted then powder coat a clear and they remain looking new .Come to think of it , I am  Not sure if we clear coated the tanks on the RedKid .
tony
Alum slots imo are period correct and just look right on most vehicles from the 60s and 70s. I do like and was going to suggest stock steel wheels and hubcaps for this project too. Maybe a lil wider than original, at least on back?
I am looking and when I find something better I will jump .
tony
Ford steel wheels should fit through to 98, Dodge should fit until 94, I believe bolt pattern is 8x6.5, center hole of Chevy is too small, not sure you will find a 10” rim though and can’t say if hub caps will fit if you go that route, might be more choices now than years ago
Recall looking at a Chevy truck in the 80’s that had wide rally wheels, never offered by GM, widest factory was 8”, he had the tools and skills to cut and extend them out to 10” with another set of sacrificial rims, you can just buy them aftermarket and wider now
  • 4 weeks later...
Work has slowed lately!   12/22/20
working on bed , mostly now fitting new lites going to fit a B&w gooseneck hitch , and fitting tool boxes in front of rear wheels along frame.
Tony
  • Like 5
  • 4 weeks later...
On 1/23/2021 at 12:39 PM, Tonyinca said:
Not much going on
 they are working on odds and ends and dealing with covid problems at the shop.
tony
Fwiw..... I am confident them Indy rims will be just fine under 99.9% of conditions.  The aluminum wheels today are as strong as steel.  Or better possibly.   I swore she was a dually but didnt look back at pictures to refresh.....?  I love going up to a 18".  Better ride/handling and more common today.  Touch of modern and still style of 70s.  Good move.  Also... Wheel Vintiques may be able to get/make you a 18" steel patterned after the OEM.  The cool kids are running 20 to 22" steel rims nowdays.  Look that up.  Some look like oem raylle rims etc with correct period caps but big sizes.
Looking too good to work.. ?
What would Herb say?
Troy ,
I think Herb would say “ Crazy Portugee”
with a big approving smile on His face !
He was Danish and pretty conservative !
tony
update ;
Dash attachments are all in and set.
engine is in and all mocked up
lights are in and being fitted in new positions on rear .
new steering box that may work
Clarence lights positions over hitch area center bed
tony
few pic’s
  • Like 6
Little more progress !
painting intake , remember this will be running on propane . Engine has been taken for balancing
rear lights are being repositioned and will have back up lights .
we received the tool boxes and they are being fitted . If you notice on third pic the B&W hitch is also being fitted .
tony
1 hour ago, Alan Dinan said:
Going to be too nice to use, Tony. I would be afraid of scratching it or a dent!!
Going to try to be careful .
Hoping to use it in conjunction with the tractor collection , either service truck or have Gooseneck and tractor paired with it at tractor shows .
yes , after all the time and money spent it gets a little fun /nerve racking using it .
tony
