1966 1200 Factory LP Flat bed.
3 hours ago, Rawleigh99 said:
Was the flatbed factory or did he build that?
  He built the flat bed .
    When he bought it it had a pick up box.
      Tony
More activity from Grass Valley , IH parts of America.
8/20/20 progress
frame getting ready for fittings
cab is still being sound deadening and heat insulation on roof , back panel ,
tony
20 minutes ago, twostepn2001 said:
Tony, this might be a bit early in the game plan, but are you going put A/C in this one like you did the red one?
Yes , will be vintage air.
tony
4 hours ago, TroyDairy said:
A/t and p/s this time.....1st....as well?  ?
Yeah Learned my lesson !     Air and Power steering no question.
         However, tranny will go from four speed granny to 5 speed overdrive.  Trying to keep with the work truck motive'
      Tony
  Starting to build frame up.
    Needed to pick wheels for it  ,
        Going with an older school style  Indy polished 17 X10  Will be matching up with Michelin  Light truck  type road tires.
         Tony
  • 4 weeks later...
10/6/20  progress being done .
fitting cab , steering column , axles , (engine 392) , wheels , etc. vintage air .
this is preliminary fitting prior to powder coating frame and painting body .
this is the exciting phase for me .
pictures
tony
Tony, this might sound like a minor trivial thing compared to the bigger parts, but l noticed the brake and clutch pedal pads are pretty well worn out. Where do you find replacement pads like that? l know my son gets a lot of his Ford pickup parts from LMC. ls there a place like that for IH pickups?
Yes they fitting in with original seat and peddles .
they restore Scouts and specialize in I. H.
I have not asked them but I am sure they have them in stock .
the problem I am having is same as with RedKid with original steering wheel  . Using new column leaves us with wrong splines , only way to use original wheel which I want and did with RedKid is cut top of shaft and weld on top of original shaft .
i think these trucks would look ridiculous with a racing or sporting steering wheel
10 hours ago, redturbo said:
Not polishing the valve covers?  ?
Great to see work being done on the truck again.  Classic looking rims,  I like it.
Thanks !
will probably be polished by time it’s all done ! Lol
tony
Little more progress today !
fitting continues , 392 fitted with five speed overdrive . It had a 304 with granny four speed .
column being fitted for power steering .
btw I intend to still run it on LP as it was equipped from factory
Tony
We have to see when all is painted and together wether it adds to put it on .
I am trying to have more of a everyday look and service truck with this .
Redkid was done as more of a IH pick up can hold its own next to Chevys and Fords at car shows .
tony
 Very nice Tony , glad you and Carol got to take the red kid out on the town ?
‘Danny
update on Herbie . More progress!
working on hiding AC equipment under fender well, working on installing two speakers in dash and in doors . Working on trying to find a speedo / tack that can fit same hole on dash and look original .
tony
  • Like 5
