Removing oil cap on 2+2
2 minutes ago, Rs3480 said:
On 3788, How do you remove oil cap on front axle to check fluid? Mine is stuck and don’t want to ruin it.
They usually just pull out. It is kind of a hard place to get at. Can you twist it at all? If you absolutely cannot remove it open one of the plugs in the axle housing. I think that when the diff is full the oil should be up to the bottom of that plug.
