41 Farmall MD starting trouble
We have  a early MD with the bosh pump on it. You can start it no problem . You use it for a littlt bit shut it off and you can crank it all day and it won't start. If you pull it . It will start right back up. It has just started doing this after we went to a plow day. We are stump on what is wrong with it . If anybody has an idea what it could be it will be much appreciate.
If the problem on the gas side is not starting when hot and you have a magneto more than likely the coil is causing the problem.
