806frank 15 Posted July 16, 2019 Share Posted July 16, 2019 What all needs to change to put a 282 in a td9 crawler? Flywheel, clutch, front pulley, side rail length? Thanks for information. Quote Link to post Share on other sites
DWF 51 Posted July 17, 2019 Share Posted July 17, 2019 I don't know about your questions, but on the older gas start TD-9's, you needed to change the oil pump and oil pan when using the engine from a WD-9 etc. This was due to the fact that the crawler can be operated at some extreme angles. I don't know if a 292 is that way, but I would suspect so. DWF Quote Link to post Share on other sites
McCormick 40 3 Posted July 18, 2019 Share Posted July 18, 2019 The newer ones had a 282 in them. The older ones I don't know if it would even be possible, at least not with more work and headache than it is worth. Quote Link to post Share on other sites
nomorejohndeere 419 Posted July 23, 2019 Share Posted July 23, 2019 Not mine On facebook marketplace in Freeport IL for $200 Quote Link to post Share on other sites
