86 series PTO experts
New Englander
786 PTO engages but won't latch. Can't find my manual; suspect a pressure issue but don't know.
Help! As soon as someone tells me how I'll also find the manual! ?
Doesn't slip when it does latch in, takes many tries to get it to stay latched. Rod is adjusted to fully push valve down.
I don't think your pressures are right. I did a pto on a 1566 that would not lock in before, after I rebuilt it and adjusted the pressure it stayed locked in. You need to put a gauge on the two plugs on the left side of the housing right below the valve. I don't remember off hand what the pressures should be but I'm certain someone on here will.
