RedPower5488
5.9 cummins in a 706
I'm just wondering if the motor out of a 1996 pickup is too new to work in a 706 without too much trouble. Is there anything different from a 1996 compared to a late 80s dodge Cummins (electronics, pump ect.) The reason I ask is because my old farm truck is clapped out in all areas except for that beautiful motor and I would like to do a 706 Cummins swap and I was wondering if this motor is too new. It is my understanding that I need an adapter, flywheel, clutch, and throttle linkage from Leaman's along with a maxxum exhaust manifold and thermostat housing and a radiator with the ports on the correct side. Anything I'm missing? I followed the thread from hemlock farms but that motor came out of an 89 dodge truck.
Message Cwinn on here. Hes done one
A 96 dodge Cummins would be a 12 valve engine with that beautiful Bosch PE pump and minimum electronics.  I think it would be the perfect choice for the swap.
Would need to change the governor on the P pump.  No electronics on the Dodge Cummins engines until the 24 valve came out in the '98 1/2.
Gearclash is correct.
If you are always going to be on it to regulate throttle it would not be that big of a deal, but use it in a stationary application like silage blower (variable load) and you will hate it.
I have one in a 806 I love it you won’t notice the governor much mine still has the one from when it was in a truck it’s a pleasure to drive just use it like a 100 horse and I think it will last a long time
I recently picked up a really clean 806lp and intend to put the 95 p-pumped 5.9 out of an old donor truck in it. There are no more electronics on the 94-98 than there are on the older motors. Main difference is the pump. Most people like the newer p-pump because it will make much more power easily over the old rotarty pump. I think I'm going to run mine without the inter-cooler and set it up at 120hp or so. Should last 10k hrs or more there.
On 7/7/2019 at 3:08 PM, redturbo said:
This was at rpru 2019
My 706 made it up there but of course I was busy at home cutting wheat. Any questions on doing a swap, dont be afraid to get in touch with myself or Ed Leaman. 😎😎
This is a 450 rear, but not a hard swap. Biggest thing is all the time.
