Bobbe
Transmission oil ih 1300d
Hello!
I've been aware of that my ih 1300d 4x4, v8 304, manual trans is leaking gear oil both from the trans and the transfer case. What oil should I use and what is the capacity in both? Any one knows?
Then also; when do I know that the transfer case and the transmission is full?
Bobbe
If you have transmission lube experience, there's probably a check hole or fill it to the filler hole? I used to use 85W-140 in stuff of that age to top it off. Some people have better ideas, hopefully.
Both fill to plug level, whatever gear oil you like.
A-ha!
Thanks.
Bobbe
