ozfarm
Upton Tractor
this got rescued , yesterday
Upton tractor
upton had this theory that a 2wd tractor should be able to outpull a 4wd tractor
so he set about building them
this is an early one
originally powered by Nissan UD4 and used M3 grant drivetrain
the grant axle developed problems, so the grant drivetrain came out and 2 x 5speed gearboxes fitted,along with a mack diff     original UD4 had been taken out and a AEC/Leyland V8 engine fitted
inside of the M3 grant diff assembly
Those nissan UD engines are a great reliable engine.  Does the V8 turn over?  Going to fix it up?
That name sounded familiar.  There is no way in **** that tractor would out pull any 4x4 the way its setup.  Found this article in my Farm Show magazine.  There are a couple other articles on guys building their own big 2 wheel drive tractors and claiming they are just as good or better then a 4 wheel drive.  Two things.  Upton and these other guys don't know what hills are and don't know the meaning of "efficiency."  A 350 hp tractor weighing 51,000 lbs??
I tend to agree with you
or what happens when a heavily weighted and loaded 2wd tractor does in soft soil
same thing seems to be happening with large FWA tractors,             equal size 4wd , still outperforms  them
