SJH
7130 headlights and flashers
So lately the flashers on my 7130 have been acting up and when I'd leave the field that have to kind of turn them on when I hit a bump and then start working but now I have no no headlights or flashers but I have tail lights is there a ground somewhere I missing or is the switch bad ?
I'm not sure exactly how we would know why your lights don't work.  The best thing you can do is get a multimeter or test light and conduct some tests of the lighting circuit.  If I were doing it, I'd start with the switch and see if you have power coming out of it.
The "hit a bump" to start working sounds like you have a bad connection in the main wiring to the lights switch.    Check the fuse and work your way toward the switch.   Use a test light or meter.
