Binderoid
1940 M u-joint
Cut your old joint off of the shaft and then go to a parts house and order a complete universal joint assembly for a 7/8” shaft.   Order a joint with holes to roll pin it to the existing shafts. I like to use the heavier spiral roll pins, or you can drive a smaller roll pin into the bigger roll pin.
That is a factory ujoint for an early tractor nobody ruined it by welding on it that was produced before the clip type ujoints  if you look closely you will see four bolts holding the webs together . I may have some nos webs for it but you would still have to grind off the welds and `replace the pins. If it were my tractor I would just get a complete shaft from a later tractor with the cross and bearing kit as those old stlye one were replaced for a reason they were always a little loose or a lot loose even when rebuilt with new parts
