Rich
1086 TA Rod disconected
The TA handle on my 1086 is disconnected just inside the firewall.  It has been that way since I bought it.  If I reconnect the rod to test it.     What am I looking for and will I break anything????
Nope hook it back up there is an adjustment down below on the MCV you maybe want to recheck
When ta is in drive, snap ring on spool must contact the nut that screws into mcv. If not, loosen jam nuts and extend rod that attaches to lever on outside of firewall until it touches. Then, if that is good, check with it in ta position, snap ring must be 1 1/8" above nut. If not, loosen handle inside if cab, and adjust for more or less travel to make that clearance.
