Rich
1086 3 point hydrolics
New song same dance.
Working my 1086.  primarily using for root plowing and box blade stump ripping.  Seems like every time I start there will find a new problem of some sort big or little.  learning how to fix a bunch of them my self.
First.  Hydraulic filter is NEW,  Fluid is FULL, Fluid is clear and fresh (I keep bursting steel hydraulic lines).  (Minor leaks (as with all original older tractors) but nothing major.
This one is intermittent (started before filter change).  when I start the day the 3 point lifts and drops at the flick of the lever.  As the day progresses the lift works great but the drop will take from 15 to 20 count to drop, often missing my intended target.  Can work around it but a pain in the &($%$$#.
Any ideas???
Hitch drop check valve out of adjustment, do you have a book.    Steve
Yes have the chassis repair manual and the parts book
Found the Hitch drop rate adjustment in the users manual on page 51.   Can not locate it in the Chassis manual or parts manual.  have traced the linkage to the 3 point but have no idea where the Pressure Flow hydraulic system is.
Where is this turkey located??
THANKS!!
Needless to say I have NO idea what I am doing, But learning!
You can call me tomorrow afternoon. 4one9 82two 729six. Steve
