My new to me IH 71 three wire baler arrived !
Sorry to hear Tony. Prayers for you and Carol.
Here is a video Tony sent me to post of getting it lined out.  Looking good Tony!
edit: correct video is below
Awesome!!! I am totally amazed at the amount of work that takes as well as the quality of the restoration. Almost unbelievable..........
https://youtube.com/shorts/IHiG7rzgkaA
3/25/31
I screwed up and sent wrong older video , have one with pickup running and no squeak , lol.
she almost made  it out of shop today but not quiet!
Got my nose piece , hitch , drop pin , bale weight indicator , light wires , all arranged ,
Shimmed up auger belt to proper tension and got pulleys running true.
all chains are on and operating properly .
NOW THE HARD PART DIALING IN THE NEEDLES , needle brakes , timing ,
then time the feeder fork.
after that should be ready for wire !
tony
Never thought l'd get excited over seeing a video of a baler running but l sure did like this one!! Thanks Tony and Hammer for putting this one up.
That is a piece of art, Tony!!! Looks fabulous, and sounds like a watch running!
Only thing that I am curious about is that it doesn’t have a wind guard? Is that not an issue out west?
22 hours ago, iowaboy1965 said:
Looks better than new Tony! Nice job.
Yes.  Probably the best-looking baler I have seen.
Thank you for sharing the video.
Thank you Alan , I hope I can get it to tie like a watch ! lol lol
I think by wind guard you mean the spring loaded fingers that hold down windrow as it comes up reel ? It’s here ready ,just keeping it off to make it easier to reach things on Baler .
we still have four shields to install but they will go last , along with a piece of sheet metal that goes over the knotter clutch that squares sheet metal in back .
tony
No good deed goes unpunished ! Lol lol
worked all afternoon to time feeder fork , should of been simple , read op manual ten times over, think I got it , however , cannot get pinion sprocket to go in . I have cleaned all , it all fits nicely off but going on it binds on woodruff key 3/4 of way in , I do not want to pound it more then medium taps with rubber mallet , guess I’ll go get a new key today and try it that way ! HUMM !
On Happy note have all my lights wired , grounded and working as should .
BTW, the timing on feeder fork is the shorter of the three forks ( first one on left )needs to be 2” above face of plunger approaching on compression stroke. Got it perfect gears mesh perfect , but that little devil will not go in last quarter inch .
tony
  • Like 10
