Vanstractors 120 Posted April 28, 2019 Share Posted April 28, 2019 Draining Hyd fluid to upgrade tp dual pto .Drained 3-8 ths plug in bottom of axle housing didn,t get but a few gallons .Quit and thought I would pump through one of the remotesThis housing is apparently somewhat separate from the main supply. It will fill itself I hope when I refill main supply ?Thank You ! Quote Link to post Share on other sites
88power 1,570 Posted April 28, 2019 Share Posted April 28, 2019 Park it with the nose over a hill helps and you don't have to drain as much.Better have a hoist of some sort to help you get out and in those things aren't light. I took one out over the winter and I had to change the filters anyway so I drained it at the filters and the plug under the draw bar. Quote Link to post Share on other sites
Vanstractors 120 Posted April 28, 2019 Author Share Posted April 28, 2019 Thanks I have the rear up on blocks found a clean 55 gallon barrel thought I just pump into it and use hand pump to refill 1 Quote Link to post Share on other sites
