TGFAIN 0 Posted April 25, 2019 Share Posted April 25, 2019 I'm working on my 504, trying to replace the seals on the IPTO shaft in the transmission. How does the shaft come out? Do I have to pull the gear out to get the shaft out? I have already remove the throwout bearing and the cross shaft to the clutch pedal. Quote Link to post Share on other sites
TGFAIN 0 Posted April 25, 2019 Author Share Posted April 25, 2019 This is the shaft I'm talking about. I need to replace the bearing and the seal behind it. Quote Link to post Share on other sites
CIHTECH 438 Posted April 25, 2019 Share Posted April 25, 2019 I can't see it in your picture but there is a big square headed pipe plug below shaft. Remove pipe plug and then remove the 1/2 bolt. Lightly tap on gear and a tapered split ring will pop out. Remove lower gear and now you can pull top shaft. I can't remember 100% but I think you will also need to remove bottom cover. Quote Link to post Share on other sites
mmi 369 Posted April 25, 2019 Share Posted April 25, 2019 this gives a view of parts one set is in #7 which you got out IIRC you have to remove gear 47....? pg 150 https://www.messicks.com/cas/63547 340/460 would be the same dont keep any service books at house Quote Link to post Share on other sites
TGFAIN 0 Posted April 27, 2019 Author Share Posted April 27, 2019 Thanks to both who replied. You were right on your information. I got the seal replaced and am ready to start reassembling. I appreciate your help. Quote Link to post Share on other sites
