Missouri Mule
4l80e guys
Ever have a bad day? The other day my truck blew an oil cooler hose on the highway. I caught it quick because it was spraying on the manifold 😳. Lots of smoke but I got it pulled over and repaired the hose. Limped it 1/2 mile and put 2 qts of oil in. Dipstick showed full so I thought. Here’s where it gets bad. I drove it a few days feeding cows probably 5 miles each day. Today on the way home it wouldn’t shift into od or lockup not sure which. Was only 1/2 mile from home when I thought damn i wish I had double checked that fluid now😢 (too much of a hurry)well it was 3 qts low!  Omg 🤬  I took it for a spin and it shifted perfect. Truth told I probably drove it 30 miles total that low short distances.  Feel pretty stupid. Did I mention this tranny is brand new? $1900....feeling real stupid now. So tranny guys did I screw it up or you think it went into a limp mode on temp or something?
  • Sad 1
Did your check engine light come on?  If it stayed off I wouldn’t worry about it as long as the fluid doesn’t smell burned.    The weak part in those transmissions is actually the torque converter clutch inside the converter.  3 quarts low sounds about right for not shifting all the way up.
           I was a tranny guy at the local GM dealership for 19 years.  If you did any damage, it should’ve kicked the light on by now......
No light no burnt smell. Hopefully I’m good
Never ran my 4l80e low but I've ran it hard. Pulled about 18k in my 98 K2500 with a 454 quite a few times and it's never given me any issues
