hippy5488
hitch pump
does anybody have the part # of the teflon ring and o ring to use on 66-86 series hitch pump between rear housing and pump mounting plate?  had it but lost it in my fine fileing system that i have.  tia
395312R1
With all due respect to CIHTECH...I use a different set of numbers. Hasn't failed me yet.
238-6122 is the o-ring.
388591R1 is the teflon ring.
Travis
Interesting......I use the Ag Parts 395312 which is same as CNH 395312R1 either way I think either / or would work. I will place a 388591R1 on my next order just for comparison.
Here are some shop notes I have
O-RING ON HYDRAULIC PUMP FLANGE CAN BE SUBSITUTIED FOR PART NUMBER 395312R1 WHICH IS A TEFLON RING
NOTE; THIS WOULD REPLACE 238-6122 O-RING
NOTE; 06-26-56 SERIES TRACTORS CAN HAVE PUMP MOUNT # 387348R11 WHICH USES 272975 O-RING
NOTE; FOR SEVERE CASES OF A BLOWN PRESSURE PORT O-RING SEE SERVICE BULLETIN S-3726
The o-ring fits inside the teflon ring. Works great that way.
Travis
