Help please! This truck has been my nightmare for the past few weeks. 1999 International Navistar 4700 T444E. Click No Crank with a key turn. (Click seems to be coming from the starter solenoid)
However- when I jump the truck with a Boost Pack from positive post next to battery box it fires right up no problem every time.
- Read codes "152" and "626".
-The truck has 2 brand new 12v batteries in parallel.
-Fuses are good in battery box.
-Cables from battery box along frame rail to relays/ecm/starter are in good condition not frayed or exposed.
How should I start troubleshooting this? I've seen some issues with fuses in battery box, relays, and ECM- Where should I start? Thanks a lot in advance to anyone who has information on this!!!
If the click is actually coming from the solenoid you are short voltage at the switch terminal. If you have a starter relay that is the circuit to check. If not add one.
clean the connections also ground to frame etc  cab ground to frame can act up also
