Red Binder back on restoration jacks
Tony, could I make one suggestion , This is probably one of the nicest upgrades for ease of driveability , along with unequaled customer support
from IH parts America and the guru of injection Bill Hamilton himself , The kits he offers are  100% plug and play
Hamilton TBI Fuel Injection System for your IH Pickup, Scout, Travelall - IH Parts America
Hamilton Fuel Injection
  • Replies 176
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
DONE AT CUSTOM CONCEPTS ! its headed to upholstery shop ! one of Robs guys shinning bumper and Rob touched any small paint nicks on engine. it will be covered at upholstery because probabl
Nice quiet Saturday in January , warm and dry .  took the Red Kid out for little  leg stretch . she’s doing well . they are planning a car show ,local in Feb .  keeping figures crossed i
6/4/20  Upholstery is done !! re upholstered the rug because other got damaged during all the changes  .  the seat was redone because I was not satisfied with previous pattern. it now
Posted Images
10/8/19
visit to the red binder this AM
found engine , tranny , rear end being set to the degrees needed to avoid vibrations
after today if all goes well all mounts should be welded in.
i can’t believe the amount of engineering that goes into a build.
the rear end is a Ford 9 bolt , the tranny is a 700r.
Rob himself making tranny cross member
and few other pics . Notice the two degree meters on engine. Going to have to use  relocate bracket for oil filter
tony
  • Like 6
mounts are made and welded for tranny and engine.
trying to save original steering column , want the look and steering wheel
Rob is planning on cutting it and using knuckle joints to connect .
tony
  • 1 month later...
11/10/19
All the steering parts are in .
had to go with new steering post that looks very original but with tilt wheel.
had to re work exhausts .
everything being mocked up prior to weld solid .
the power steering pump found a place for brackets and is mocked up
tony
  • 4 weeks later...
1/6/20
      Happy New Year !
         Progress is very slow but moving forward.
          Fitted rotors and wheels  and set truck on floor to get our stance . The matching master brake cylinder to disk brakes , we eliminate need for booster cylinder. Pic. #5
       Need to de arch rear springs for lower but they have been de arched once already. Ride would suffer , or we could mount  springs over rear axle but that's not something I want. Pic. #1
       Decision is to build a Coil Over suspension for rear .  The thoughts are that we have original frame ,updated with current state of art suspension front & rear .
    As most of you know in a modification , every action causes a reaction . Having to move few items.
       To gain proper stance for rack & pinion and fit in crowed area of power steering pump etc . we went with a new steering column, it will have tilt wheel using original steering wheel. Pic # 4, 5 .
       Here are few pictures of on going work
        Tony
  • Like 6
update on the red kid !
coil over is installed and trying to determine stance as far as lowered and front rake.
lot of little detail being done such as brake lines , power steering pump and reservoir
linkage to carb are all being redone due to Auto tranny
clutch peddle removed and new gas peddle. New gear shifter mounted .
few pics
Tony
  • Like 7
What is PSC Can near radiator ???
Pretty nice to get the disc brakes on ,did you have them design for the truck?  Do you have them on the rear also? I didn’t look at all the pictures ,just recents !
 Yes that what created all extra work .
           New axle to  accommodate disk brakes.
      Tony
THANKS !!!!!  This story is such a great break from the norm on this site.....
Thank You ,
    I see your a retired truck & trailer Mechanic and Fabricator,  You know all the work and problems encountered in modification !  One thing leads to two others . lol.
    Tony
Tony,
Thanks for the updates! I always thought one action caused at least 5 new actions! The truck looks great. "low ridin binder"! or "candy apple corn crusher" or "sweet binder"
Its going to preform and handle like a new truck with all the up grades too!
Regards,
 Chris
 More of the behind the scene stuff being done.   !/21/20.  Goal is be done on April 30ieth . Get bugs worked out and be ready to leave for Huron S/D on June 15,20.
    She is coming along  , soon will be done and ready to dismantle and Powder coat frame and paint what's needed.
   The oil pan had to be changed to one used in a straight axle application . If you remember this truck started a Torsion suspension.
    Being tank is being moved to back of bed , The fuel access hole in cab is no longer needed and gone.
     Tony
  • Like 6
  • 3 weeks later...
On ‎2‎/‎12‎/‎2020 at 8:59 PM, redturbo said:
Tony,  did you see that IHPA has aluminum valve covers now!  Looked pretty sweat all polished up on your engine.
Aluminum Valve Cover w/ International Script for IH 152, 196, 266, 304, 345, 392 Engine
Thanks for heads up
   Tony
On ‎2‎/‎13‎/‎2020 at 3:25 PM, KWRB said:
Is that 2150 (or a premium version of it)?
 I gave him a sample of my shade of 2150 that I use on my tractors ,which is Top grade Automotive Poly Urethane  By Valspar and tinted by my painter.
    He then matched it to the latest PPG water based concoction allowed here in California.
     Both paints are single stage.
       Tony
       Tony
That's cool. That's really the spirit of what I was asking -is it intended to look like a tractor. I love well done projects like this.
Thank you ,
Not necessarily to match tractors but to be a good quality red for the vehicle
tony
Today 2/17/20 Here she is !
Running gear is complete and final welding done sanding and prep for powder coating done and it’s off to powder coat
and other parts being painted .
cab fuel hole is totally welded in as tank was moved to rear of bed. Also cab will have work done on cradle for steering column
few pics
tony
  • Like 6
Hey Tony, l'm not sure but l think you been hacked on FaceBook. l got some messages on there that just don't sound like you. l tried sending you messages here in the Red Power messenger to let you know but for some reason it ain't working.
