TGFAIN 0 Posted February 10, 2019 Share Posted February 10, 2019 Can anyone tell me the thickness of the head gasket against the sleeve on a DT361 engine? Want to make sure I received the correct head gasket. Link to post Share on other sites
snoshoe 467 Posted February 10, 2019 Share Posted February 10, 2019 Not sure what your looking for here. The gasket does not sit on the sleeve in this engine. I do not know the thickness of the gasket either new or compressed. The compressed thickness would have to be greater than the installed height of the sleeve. That spec I do not remember as I used the special installing plate which set height automaticly. It should be in the manual. Link to post Share on other sites
J-Mech 1,269 Posted February 10, 2019 Share Posted February 10, 2019 15 hours ago, TGFAIN said: Can anyone tell me the thickness of the head gasket against the sleeve on a DT361 engine? Want to make sure I received the correct head gasket. Short answer: no. That's not a spec that you need. Different manufacturers, different materials..... you would never get a consistent answer. If you need to know sleeve height, it's in the service manual. Link to post Share on other sites
