I know this topic has been addressed in some form already, but I am still unclear about some specifics. I want to connect a loader valve to a 1981 IH 886. It has the supercharge line to the MCV from the end plate of the auxiliary valve stack. I don’t want to use the rear remote to power the loader. I would like to tap in to the tractor hydraulic system at the aux. valve under the right fender. Can I put a T in the supercharge line for supply and return the flow with a T in the larger line that enters the tractor rear housing below the valve stack? Hope this makes sense. Thanks in advance.
2 hours ago, striker782 said:
The 886 didn’t offer PPH hydraulics.
Gotcha, I wasn't sure.
There is actually a TSB from IH that suggests deleting the supercharge line to correct certain issues. That tells me that it isn't totally necessary and I've deleted it on my tractor and used the outlet on the valve stack to supply a loader valve just like you're talking.
