lach13 Posted January 20, 2019 Posted January 20, 2019 Hi all, after running the 786 today and travelling some time with the implement in the air it became annoying when i found that with the vibrations of the machine that the 3pt linkage lever would creep down causing the implement to lower. I know I could just set the stop in the raised position but i don't want to have to move that every time i want to transport the implement. So what im wondering is if there is a simple linkage that I could tighten to make the linkage lever a bit harder to move and therefore not be able to vibrate down on its own. Thanks for your replies in advance, Lachlan
Qc.Can.IH man Posted January 20, 2019 Posted January 20, 2019 6 hours ago, lach13 said: Hi all, after running the 786 today and travelling some time with the implement in the air it became annoying when i found that with the vibrations of the machine that the 3pt linkage lever would creep down causing the implement to lower. I know I could just set the stop in the raised position but i don't want to have to move that every time i want to transport the implement. So what im wondering is if there is a simple linkage that I could tighten to make the linkage lever a bit harder to move and therefore not be able to vibrate down on its own. Thanks for your replies in advance, Lachlan That’s very easy to fix, if you look under the fuel tank on the right side of the top rear end housing you will see the linkage from your levers going into the cover, just tighten up the inside bolt as shown in the picture.
lach13 Posted January 21, 2019 Author Posted January 21, 2019 Thanks just hadnt had time to look into it and knew someone on here could give me a quick anwser
