Paystar5000 46 Posted February 18 I have the snap on one and I made one out of a5/8 craftsman wrench. Funny they kind of compliment each other. If you turn the bolt and it doesn’t go quite far enough fo the snap on one to catch it the other one usually will. A set of S wrench’s will come in handy also. I usually take the power steering pump and oil pump off but it can be done without it. Quote Share this post Link to post Share on other sites
dale560 863 Posted February 18 9 hours ago, Paystar5000 said: I have the snap on one and I made one out of a5/8 craftsman wrench. Funny they kind of compliment each other. If you turn the bolt and it doesn’t go quite far enough fo the snap on one to catch it the other one usually will. A set of S wrench’s will come in handy also. I usually take the power steering pump and oil pump off but it can be done without it. Exactly. We have 2 wrenches like you said . Use one then the other. Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted February 18 Thanks for the replies. I was out there today and may have put my finger on that bolt. Maybe. Might have to find someone with little hands, mine sure don't fit in there. Quote Share this post Link to post Share on other sites
dale560 863 Posted February 19 5 hours ago, Dave Shepard said: Thanks for the replies. I was out there today and may have put my finger on that bolt. Maybe. Might have to find someone with little hands, mine sure don't fit in there. They fit in there if you make them. I have fat pudgy hands and get it done. Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted February 19 I tried, no way my hand fits back there. I'm thinking 50 # tannerite...... Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted February 27 Found a wrench I bought 30 years ago and never used. I think it'll work, or will get bent so it does work. Just waiting for warmer weather. Next question. Is any part of this assembly timed? It doesn't seem as though it should be, but one guy on YouTube was talking about it. Thanks. Quote Share this post Link to post Share on other sites
dale560 863 Posted February 27 9 hours ago, Dave Shepard said: Found a wrench I bought 30 years ago and never used. I think it'll work, or will get bent so it does work. Just waiting for warmer weather. Next question. Is any part of this assembly timed? It doesn't seem as though it should be, but one guy on YouTube was talking about it. Thanks. No they aren’t timed just splined shafts. I use a wrench like that and a short craftsman box end you get them loose eventually. Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted February 27 Thanks. 8 F now. I think it can wait until a warmer day. Quote Share this post Link to post Share on other sites
BrownDirtCowboy 0 Posted March 4 I finally got the compressor off. Having trouble reaching the bolt to help put wrench on bolt head, this being on a cabover the shift tower was in the way, unbolted tower and moved it. Took an hour to get the bolt out, am going to give 2 to 3 hrs to put it back in. Good thing I'm not in any hurry. Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted March 26 Got mine out today. Obstruction wrench wasn't obstructiony enough. Torch took care of that. I'm not sure which was worse, pulling that compressor, or taking the steering column out of a 3010. Some really odd thought processes going on there, and I'll leave it at that to be polite. Quote Share this post Link to post Share on other sites
dale560 863 Posted March 26 25 minutes ago, Dave Shepard said: Got mine out today. Obstruction wrench wasn't obstructiony enough. Torch took care of that. I'm not sure which was worse, pulling that compressor, or taking the steering column out of a 3010. Some really odd thought processes going on there, and I'll leave it at that to be polite. That column on 3010 is definitely easier. Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted March 27 Yeah, but it's green. There's a 2640 in the shop, too. That needs the entire machine disassembled to clean out the brake lining that migrated through the entire hydraulic system and rearend/transmission. Quote Share this post Link to post Share on other sites
Dave Shepard 65 Posted March 28 The truck is running. What a debacle. It only took about three hours to get it back together, and that was with putting the power steering pump back on, and some other things that I'd taken off that didn't help. I took the PT pump off before the compressor. I bolted it back on before I put the compressor back on. Much easier, other than holding the entire contraption up with one hand while you try to start a bolt with the other. What are people using to pull that gear off the old compressor? I had to take it to a shop that had a snap on puller with legs that went in a yoke, and a lot of heat. A traditional jaw puller wouldn't fit in there. Quote Share this post Link to post Share on other sites
dale560 863 Posted March 29 On 3/26/2019 at 7:02 PM, Dave Shepard said: Yeah, but it's green. There's a 2640 in the shop, too. That needs the entire machine disassembled to clean out the brake lining that migrated through the entire hydraulic system and rearend/transmission. Yes that is a problem with internal brakes. My buddy had a guy change his compressor on a n14 and they heated the little spline gear it broke about 3000 miles later involving a tow back to shop. Quote Share this post Link to post Share on other sites
