Adding/checking lift-all hydraulic oil
I’m trying to get all my oil levels checked and I’ve changed engine and transmission oil   And I read on here that the belt pulley get its oil from the tranny oil but to add a pint.   I have a manual but from what I can tell I have the live engine lift all and nothing looks the same in diagrams.  It’s a ‘54 super h.  S/N 26011 J
7 minutes ago, nepoweshiekfarmalls said:
Lift all is separate from transmission housing. The housing just ahead of the belt pulley has 2 plugs. The lower is the drain. Fill until it runs out the upper plug.
I’m assuming you mean this plug to fill  (pictured) and if so. How the heck do I get it out.   Tried using half inch ratchet but it won’t fit in. It’s just a little too big. Could always use die-grinder to make but was gonna ask someone first
The fill is the pipe on the other side. Someone used it for a return. It's the hole behind piece of water pipe sticking out the side, then elbow going straight up to a tee, which then goes to hoses front and rear. All you gotta do is remove the little pipe cap and add your oil until full.
I don't know what the plug you're trying to remove is, but it is not the fill.
Can you over fill it and cause issues?
