pro 700 w/ auto steer in older magnums
What is the oldest magnums I can put a 700 with controller in and use auto steer function properly
I am pretty sure “boxcar” magnums are too old maybe not
but how old in new style magnums
thanks for the info
Just now, AZ8950 said:
I have one in an 8950. Works fine. I'm not sure what the harness is called but there was one available.
Ok do you use the auto steer function?  That’s the main thing I’m after so my help can drive a straight line🙄
Yes. I had it set up on RTK. The tractor was originally running a Trimble FMD. Switched out the wire harness and changed the Nav to CNH. I did this so that I could just run one display when I purchased a 1250 planter.
Gen II magnum like MX210-285  were first with AccuGuide ready wiring and valve, but they may not have the correct display harness.  Anything older would require an Autopilot valve and a All makes unlock in the Pro700 with an all makes harness for hydraulic autosteer.
(The other option out there is Electristeer.)
